Dashboard from JSON responses
I am looking to create a dashboard from a JSON response JSON example:
“id” : “TLS1”,
“ip” : “www.com pany.com/192.168.1.100”,
“port” : “443”,
“severity” : “INFO”,
“finding” : “not offered”
The full JSON has around 50 checks contained
I am just looking for something simple like a panel showing “healthy” and showing the ID if there is an issue
Would this be done through the SimpleJSON plugin?
Could anyone advise or provide an example to work backwards from?
(I am new to API’s and JSON, Trying to learn as quick as possible)
