Dashboard error displayed in upper left hand corner of dashboard panels
    Grafana server v8.4.3 running on linux Ubuntu 18.04
    Plot data from time series InfluxDB
    Created Dashboards where data is collected 400ms intervals.
  • What happened?
    Can get error message in upper left corner of dashboard running on Windows accessing Grafana server
    No error messages and all the data plotted
    Given data is received every 400ms there can be a lot of data points. It is necessary to show data point, need to see spikes which may be hidden if points are averaged together.
    On window machine getting the following error
    read tcp 172.31.30.229:47280->172.31.33.9:8086: use of closed network connection (Client.Timeout or context cancellation while reading body),read tcp 172.31.30.229:47280->172.31.33.9:8086: use of closed network connection (Client.Timeout or context cancellation while reading body)
