Dashboard disappeared
Hey there. How are you?
I need help. I was editing the json of a card to try to align the title in the center and after I inserted the “align”:“center” tag the entire dashboard disappeared. Is there any way I can get it back?
You have some error. Check browser console for the errors. Simple. page refresh may help as well.
Lucky I had made a backup. In the end I ended up deleting it and using only the backup. But I appreciate your response. Thanks.
