this is one of the metrics we can get:
http_request_total{handler="/datasources/proxy/:id/*",method="get",statuscode="200"}
Is it possible to get:
http_request_total{handler="/datasources/proxy/:id/123",method="get",statuscode="200"}
http_request_total{handler="/datasources/proxy/:id/456",method="get",statuscode="200"}
etc?
Not without changing the code for reporting metrics. You should open a feature request on GitHub.
Thanks for the quick reply. I did submit an enhancement request: Ability to customize grafana internal metrics · Issue #16828 · grafana/grafana · GitHub
We are also trying to use the API (passing the datasource IDs), but not getting the status codes returned that we expect. Not sure if this is a valid work-around…
