I have imported a dashboard and the custom variable ‘TopResources’ does not seem to be working. For instance, when I select ‘3’ for TopResources it does not narrow it down as expected. It still displays all the results instead of the top 3.
Grafana v7.3.0 -
I am trying to narrow down the top resources and not have all resources appear in panels. -
Using a Custom variable that helps narrow down the top resources -
What happened?
It does not narrow down the resources. -
I expected it to narrow down the results. -
Datasource is Prometheus
query: topk($TopResources, netapp_volume_avg_latency{datacenter=“$Datacenter”,cluster=“$Cluster”,svm=~“$SVM”,volume=~“$Volume”})
N/A -
Nope
