Hi all,
is it possible to set the “To” time relative to the “From” time using the Time Picker control of the dashboard just like using “now”?
Like so:
I would then like to switch the “From” time by 24h forward or backward using the arrow controls to compare data from 9pm to 3am for different days (or just select a different day from the calendar, keeping the range …)
How do you achieve this ?
Kind regards from Frank …
