Hi.
I’m very new to Grafana and I’m trying to understand if it can be used in my use case.
I will soon need to deploy a Wazuh manager on a production environment. Wazuh is useful to visualize on a central location (manager node) security events happening on the agents that are monitored.
I want to replace the dashboard provided by default, because I feel it’s kind of slow in certain situations. The original dashboard is based on kibana and uses some restful API and the backend Elasticsearch storage to fetch the data that it needs.
I already made some research and I think it’s possible to integrate Grafana to it, and eventually replace the default dashboard provided with Wazuh.
However, I would also like to setup the system to be able to accommodate a custom dashboard for each registered user and be able to manage those dashboards from the “admin” account. So basically only the admin account should be able to modify the dashboard of any user, and the users themselves would only be able to view the data the admin wants to show them.
Is it possible to use Grafana for this use case?
What would I need for handling the access management in this case?
