HI team I have deployed the Grafana as a deployment set in Kubernetes EKS having a version of 8.0.3 the pod is running fine and no error in pod logs when I do curl to the Grafana server first 1 or 2 requesting I was getting the response but after immediate curl request more than 3 the response is too slow it is taking more than 20 seconds and some times it is almost more than a 1 min and it’s not giving any error message.
I gave resources as 1 CPU and 2 GB ram and i was using the external IP to connect the server
