11.4.0 -
Better crosshair visibility on state timeline panels -
What happened?
I could not see the crosshair inside a state timeline panel. It turned out it was there, but barely visible. If the corresponding background bar uses standard colors like red (rgb 242, 73, 92), green (rgb 115, 191, 105) or blue (rgb 87, 148, 242), then it is almost invisible. It is a little bit better with lighter colors like yellow (rgb 87, 148, 242). -
automatic adjustment of the color and/or line width of the crosshair according to the corresponding background color
ability to configure the crosshair (color / contrast / line width) -
no -
State timeline | Grafana documentation
