Suppose I have a MySql database that have multiple tables and they all contain exactly the same structure and fields, but different data. Instead of creating a panel at a time for each table, is it possible to create them all in one go?
The query will be the same “SELECT val FROM table1” but the only thing that needs to be changed is the table name “table1” to “table2”, etc. for each panel.
Is it possible to do this in one go?
