Hello!
I’m brand new to Grafana as of this week (as well as interacting with an API in any meaningful manner), and I’m struggling a bit with getting a datasource into my Grafana instance via your API. I was able to sus out the format behind getting a Dashboard created through the API, but in trying to do the same thing for a Datasource, I’m coming up short.
I get hit with the following error in Powershell:
Invoke-RestMethod : [{"fieldNames":["Name"],"classification":"RequiredError","message":"Required"},{"fieldNames":["Type"],"classification":"RequiredError","message":"Required"},{"fieldNames":["Access"],"classificat
ion":"RequiredError","message":"Required"}]
In reading a topic from the Github page, the only real solution that was working for people was when they were missing “application/json” as their content-type, but I’ve got that already. Below is my powershell code, can anyone advise?
$header = @{"Authorization" = "Bearer apikey="}
$createDatasourceUri = "http://localhost:3000/api/datasources"
$createDatasourcejson = @'
"datasource": {
"name": "prometheusApiTest",
"type": "prometheus",
"url": "http://localhost:9090",
"access": "proxy",
"basicAuth": false,
"isDefault": true
"message": "creating test datasource from api call"
$datasourceParameters = @{
Method = "POST"
URI = $createDatasourceUri
Body = $createDatasourcejson
Headers = $header
ContentType = "application/json"
Invoke-RestMethod @datasourceParameters
I’m not sure what’s wrong, as this block of code is almost character-for-character the same as the Dashboard create, albeit with a different json payload. Any advice would be really appreciated!
