Creating Dashboard to graph data from LibreNMS using MySQL
    10.3.1 on Ubuntu 22.04
    I’m trying to get grafana to graph the data that LibreNMS has collected in MySQL. The things I’m specifically trying to graph are bandwidth and latency to network devices.
    I’m trying to create a new dashboard but the query part is tripping me up. I’m not sure how to use it to accomplish my task.
  • What happened?
    I go to create a New Dashboard>Add Visualization>select MySQL for the data course(it’s already connected) and then it has the query at the bottom. This is where I’m stumped. I’ve been searching through the help docs for hours and I can’t seem to find what I need to get these queries to work.
    I expected it to make pretty graphs :slight_smile:
    I’m sure I’m doing this wrong, but when trying the dropdown boxes in the query section, and then running the query, the error I’m getting is “Data is missing a time field”.
    Numerous pages from the grafana help docs.
