Hello everyone!
I am making a table visualization in which I want to connect 4 pg data sources.
2 for prod, 2 for stg.
The first data source is cluster1.
The second data source is cluster2.
The third data source is cluster1_2.
The fourth data source is cluster2_2.
I created a switch prod/stg.
I created mixed queries:
prod
select * from cluster1.table1
select * from cluster2.table2
stg
select * from cluster1_2.table1
select * from cluster2_2.table2
Question: how to change cluster1/cluster1_2, cluster1_2/cluster2_2 depending on the switch prod/stg?
I used to have a simple query:
I created a variable env = PROD: cluster1, STG: cluster1_2
and the query was like this
select * from ${env:value}.table1
but now it’s not clear.
