My company has several Libelium sensors around the country that send data through LoRaWAN and 4G. How can I create a map of the country where I can see all the sensors and their data if I hover my mouse over them? What plug-ins should I use?
I am using the cloud-based Grafana and have next to no experience.
Thank you!
Welcome
You can use Geomap plugin
Hello, thank you! But how can I display the sensors on the map? I cannot find anything on the internet.
Could you please provide sample data? As csv, json minus sensitive data?
Here we go. Downloaded lots of USA cities from US Cities Database | Simplemaps.com
Uploaded them to sql server. added a readingdatetime datetime column and populated it with random dates so grafana does not complain about missing time column.
Use GeoMap plugin, for Data Layer config I used Marker
Here is the query with census data as sensors data (get it census / sensors )
SELECT
lat, lng,
city as 'Sensor Name'
FROM
sensors
WHERE
$__timeFilter(readingdatetime)
and state_name = 'California'
ORDER BY
readingdatetime ASC
