Hi there,
I have a little bit of knowledge about grafana. I was wondering if I could use grafana to help me study for a test by creating a sort of multiple choice question app where I can load questions in and then use it with my phone to drill through the questions.
Does anyone know if something similar has been already developed? Or cab you maybe give me some hints about how to do it?
Grafana’s original use case was to visualize time-series data, and only recently has it started adding more functionality for handling other data. In your case, I think you’d get a lot more support and features using a flash-card app, or using google forms to create a quiz.
