Create matric for counter (rain counter: rain per/day as bar chart)
I am recording the amount of rain and this get logged in InfluxDB.
The data in DB are like a counter that get increased over time.
I would like to have a bar chart with the amount of rain per day.
Somehow I get a Graph (attached), but the Values are totally confusing me.
My challenge is, I do not understand how I need to setup the query to get the data right calculated and visualized per day.
Any Advice is highly welcome. (Pictures with metrics attached)
The problem I am having are the delta values per day.
The values per day are not correct.
Thank you in advance
Br
If someone is interested in a solution:
I took the max and the min value per day and created the difference. (per day)
select max(value)-min(value) from OEQ2113585_1RAINCOUNTER WHERE $timeFilter GROUP BY time(1d) fill(null)
br
I think you could also use the difference() function
https://docs.influxdata.com/influxdb/v1.7/query_language/functions/#difference
Calculate difference between the first (or last) measurement per day.
I am recording the amount of rain and this get logged in InfluxDB. The data in DB are like a counter cps test that get increased over time. Apache ECharts, a powerful, interactive charting and visualization library for browser. … Rainfall vs Evaporation … Clickable Column Chart with Gradient. To describe a complete solution it suffices to choose one particular solu- … Let’s find the complete solution to Ax
