Create alerting-on-numeric-data
    8.4.3 enterprise
    set up an alert
    follow official guide and create table in mysql
  • What happened?
    error with “Failed to evaluate queries and expressions: failed to execute conditions: can only reduce type series, got type numberSet”
    show the table and let me set up conditions to trigger alert
    sql copy from the doc
    SELECT Host, Disk,
    CASE WHEN percentFree < 5.0 THEN percentFree ELSE 0 END FROM (
    SELECT Host,
    Disk,
    Avg(percentFree) as percentFree
    FROM alert_test2
    where $__timeFilter(updateTime)
    Group By Host,
    Disk
    ) as t
    Alerting on numeric data | Grafana Labs
welcome to the :grafana: community @soldiershen123!
Thank you for all of the information you shared, it really helps the community to understand your question better. Because the error mentions type series I wonder if you’ve chosen format > table in the alert, the default is time series
Screen Shot 2022-03-25 at 4.35.20 PM
