Create a Dashboard with a Sum() of Values in a Interval of 10 Secound
Dear Community,
I have a SQL Database and in the Database I lock the POE Voltage, Power and Current Amp’s.
To create a graf for for each induvidual Port in no Problem I can create dirct from The Database.
My Proble is as follow.
I would like to create SUM() or AVG() every 15 Minutes and put this into the Dashboard.
Database ir like this and the Port is selected by port_01 to port_**.
TIMESTAMP	          DEVICE	                TYPE	       EVENT	                        READING	            VALUE	UNIT
2022-05-08 20:37:48	  Switch_24_Port_PoE_250W	UNIFISWITCH	   port_02_poe_voltage: 52.82	    port_02_poe_voltage	52.82
2022-05-08 20:36:45	  Switch_24_Port_PoE_250W	UNIFISWITCH	   port_02_poe_voltage: 52.76	    port_02_poe_voltage	52.76
2022-05-08 20:34:33	  Switch_24_Port_PoE_250W"	UNIFISWITCH	   port_02_poe_voltage: 52.88	    port_02_poe_voltage	52.88
I wrote a Query to create this Result.
created_dt_new	       Sum
2022-05-01 22:50:00	   158,28
2022-05-01 23:00:00	   475,18999999999994
2022-05-01 23:10:00	   369,75
2022-05-01 23:20:00	   316,72999999999996
When I try to input this to Grafana I receive no Time Series I receice for each 10 Minutes a different Query.
What I want is like this for one Port.
All Ports02
My Query is this
SELECT
UNIX_TIMESTAMP(`TIMESTAMP`) as time_sec,
concat( date(`TIMESTAMP`) , ' ', sec_to_time(time_to_sec(`TIMESTAMP`)- time_to_sec(`TIMESTAMP`)%(15*60) + (15*60)))as created_dt_new,
SUM(VALUE) AS Sum ,
'Port 02 POE Spannung in V' as metric
FROM `history`
WHERE `DEVICE` = 'Switch_24_Port_PoE_250W' AND `READING` like 'port_%_poe_power'
GROUP BY created_dt_new
I hape someone can help me wit this beginner problem
Thanks
Thomas
SELECT
  $__timeGroup(timeline, '15m') AS time,
  sum(value) as value,
  portname as metric
FROM
  portreadings
  group by $__timeGroup(timeline, '15m'), portname
ORDER BY 1 ASC
fake sample data
drop table portreadings;
go
create table portreadings(timeline datetime,
portname varchar(50),
value int);
go
insert into portreadings
SELECT top 112 dateadd(hh,column_id, getdate()),
s.portname, column_id
FROM sys.all_columns
cross apply
	select 'Port 07 POE Spunnung in V' portname
 ) s
SELECT top 50 dateadd(hh,column_id, getdate()), s.portname, column_id*3.1
cross apply
	 select 'Port 07 POE Leistung in W' portname
 ) s
SELECT top 50 dateadd(hh,column_id, getdate()), s.portname, column_id*0.5
cross apply
	select 'Port 07 POE Strom in mA' portname
 ) s
