I’m trying to figure out what is wrong with my loki service before moving on to setting up tempo and cortex. It seems that loki is not able to smoothly handle one of its shards going away and being replaced. In my testing I have tried both consul as the ring storage and memberlist. I have tried supplying memberlist with a complete list of members, and with a DNS entry that will resolve to a random subset, in all cases the ring winds up unstable and inconsistent.
As loki is advertised as being cloud native, I have to assume that this is a problem in my configuration, as any cloud native software must fundamentally account for the individual components of a cloud system being individually unreliable. So far this has not been the case, and at this time I have resorted to a twice daily check to make sure that the output of /ring
shows no members that shouldn’t be there. I hope that the expected deployment of Loki doesn’t involve a human garbage collector.
As I write this, my local test cluster where I was evaluating memberlist is split brained. I assumed that the consul ring storage was a second class option since it is not documented as well as memberlist and have tried this in my testing cluster. It works fine on initial ring setup, but quickly suffers the same problems as above with the addition that reliably split brains to a 2 node ring and a 1 node ring when attempting to drain an underlying machine. I haven’t gotten to the point of simulating an unexpected machine fault (I figure that doesn’t matter if steady state operation doesn’t actually work).
Is this normal and just the way loki works? Is there some setting I’m missing to get loki to recover state or not split brain at the drop of a hat? I have many other services running in this cluster that make use of distributed state and hash rings, while only loki has these problems.
Here’s the complete configuration from my local testing cluster running on Nomad:
job "loki" {
datacenters = ["minicluster"]
type = "service"
group "aio" {
count = 3
spread {
attribute = "${node.unique.id}"
network {
mode = "host"
port "http" { static = 3100 }
port "grpc" { static = 9095 }
port "memberlist" { static = 7946 }
service {
name = "loki"
port = "http"
check {
type = "http"
path = "/ready"
port = "http"
address_mode = "host"
interval = "5s"
timeout = "2s"
service {
name = "loki-memberlist"
port = "memberlist"
task "aio" {
driver = "docker"
config {
image = "grafana/loki:2.1.0"
network_mode="host"
args = [
"-config.file=/local/loki.yml",
"-server.http-listen-address=${NOMAD_IP_http}",
"-server.http-listen-port=${NOMAD_PORT_http}",
"-server.grpc-listen-address=${NOMAD_IP_grpc}",
"-server.grpc-listen-port=${NOMAD_PORT_grpc}",
"-log.level=debug",
template {
data = file("./aio.yml")
destination = "local/loki.yml"
perms = "0644"
splay = "30s"
restart {
attempts = 100
auth_enabled: false
server:
http_listen_port: 3100
http_listen_address: 0.0.0.0
grpc_listen_port: 9095
grpc_listen_address: 0.0.0.0
ingester:
lifecycler:
final_sleep: "0s"
ring:
kvstore:
store: memberlist
chunk_idle_period: "1m"
chunk_retain_period: "30s"
memberlist:
abort_if_cluster_join_fails: false
dead_node_reclaim_time: 30s
bind_port: {{env "NOMAD_PORT_memberlist"}}
join_members:
- loki-memberlist.service.consul:{{env "NOMAD_PORT_memberlist"}}
max_join_backoff: 1m
max_join_retries: 10
min_join_backoff: 1s
storage_config:
boltdb_shipper:
active_index_directory: "/loki/index"
cache_location: "/loki/index_cache"
resync_interval: "5s"
shared_store: s3
aws:
bucketnames: loki
endpoint: minio.service.consul:9000
access_key_id: minioadmin
secret_access_key: minioadmin
s3forcepathstyle: true
insecure: true
limits_config:
enforce_metric_name: false
reject_old_samples: true
reject_old_samples_max_age: "168h"
compactor:
working_directory: /loki/compactor
shared_store: s3
schema_config:
configs:
store: "boltdb-shipper"
object_store: s3
schema: "v11"
index:
prefix: "index_"
period: "24h"
