Coordinates Values not parsing incorrect from MySQL Database
I am trying to display Aircraft Positions from my FlightRadar24 ADBS Scanner.
My data is stored in a MySQL Database.
I am using this Query in the GeoMap Visualisation:
SELECT REPLACE(REPLACE(REPLACE(c1.READING,"aircraft.",""),".lon",""),".lat","") as Aircraft , c1.VALUE as lat, c2.VALUE as lon
FROM `current` c1
  join `current` c2 on c1.device = c2.device
    and c1.`READING` Like '%lat%'
    and c2.`READING` Like '%lon%'
  WHERE c1.DEVICE = 'FR24_aircraft'
  GROUP BY Aircraft
The problem is, that my corrdinates are shown incorrect.
I tried to convert “lat” and “lon” to numeric, but this also doesn’t help.
If i inspect the Data, the JSON output just looks fine:
  "state": "Done",
  "series": [
      "refId": "A",
      "meta": {
        "executedQueryString": "SELECT REPLACE(REPLACE(REPLACE(c1.READING,\"aircraft.\",\"\"),\".lon\",\"\"),\".lat\",\"\") as Aircraft , c1.VALUE as lat, c2.VALUE as lon  \nFROM `current` c1\n  join `current` c2 on c1.device = c2.device \n    and c1.`READING` Like '%lat%'\n    and c2.`READING` Like '%lon%'    \n  WHERE c1.DEVICE = 'FR24_aircraft'\n  GROUP BY Aircraft",
        "transformations": [
          "convertFieldType",
          "convertFieldType"
      "fields": [
          "name": "Aircraft",
          "type": "string",
          "typeInfo": {
            "frame": "string",
            "nullable": true
          "config": {
            "unit": "none",
            "color": {
              "mode": "fixed"
            "thresholds": {
              "mode": "absolute",
              "steps": [
                  "color": "green",
                  "value": null
            "mappings": []
          "values": [
            "0",
            "1",
            "10",
            "11",
            "12",
            "13",
            "14",
            "15",
            "16",
            "17",
            "18",
            "19",
            "2",
            "20",
            "21",
            "22",
            "23",
            "24",
            "25",
            "26",
            "27",
            "28",
            "29",
            "3",
            "30",
            "31",
            "32",
            "33",
            "34",
            "35",
            "36",
            "37",
            "38",
            "39",
            "4",
            "40",
            "41",
            "42",
            "43",
            "44",
            "45",
            "46",
            "47",
            "48",
            "5",
            "51",
            "52",
            "6",
            "7",
            "8",
            "9"
          "entities": {},
          "state": {
            "scopedVars": {
              "__series": {
                "text": "Series",
                "value": {
                  "name": "Series (A)"
              "__field": {
                "text": "Field",
                "value": {}
            "seriesIndex": 0
          "name": "lat",
          "type": "string",
          "typeInfo": {
            "frame": "string",
            "nullable": true
          "config": {
            "unit": "none",
            "color": {
              "mode": "fixed"
            "thresholds": {
              "mode": "absolute",
              "steps": [
                  "color": "green",
                  "value": null
            "mappings": []
          "values": [
            "51.461404",
            "51.728027",
            "51.209929",
            "53.805222",
            "53.610488",
            "51.687276",
            "53.610255",
            "53.365391",
            "53.823697",
            "54.126343",
            "52.312271",
            "53.897296",
            "52.583592",
            "53.564588",
            "52.436254",
            "53.395065",
            "53.261858",
            "53.505569",
            "51.960526",
            "54.276901",
            "53.630676",
            "52.264664",
            "52.157867",
            "51.136795",
            "54.610989",
            "53.200642",
            "52.147677",
            "52.569489",
            "52.898071",
            "52.582103",
            "53.391041",
            "52.87912",
            "53.465012",
            "54.371571",
            "52.994156",
            "52.492164",
            "51.682574",
            "53.707363",
            "51.57015",
            "53.787186",
            "54.411896",
            "51.593536",
            "51.891174",
            "51.778656",
            "51.708643",
            "53.832123",
            "53.832123",
            "51.216888",
            "52.285904",
            "54.037046",
            "54.201841"
          "entities": {},
          "state": {
            "scopedVars": {
              "__series": {
                "text": "Series",
                "value": {
              "__field": {
                "text": "Field",
                "value": {}
            "seriesIndex": 1
          "name": "lon",
          "type": "string",
          "typeInfo": {
            "frame": "string",
            "nullable": true
          "config": {
            "unit": "none",
            "color": {
              "mode": "fixed"
            "thresholds": {
              "mode": "absolute",
              "steps": [
                  "color": "green",
                  "value": null
            "mappings": []
          "values": [
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043",
            "11.450043"
          "entities": {},
          "state": {
            "calcs": {
              "sum": 583.9521930000001,
              "max": 11.450043,
              "min": 11.450043,
              "logmin": 11.450043,
              "mean": 11.450043,
              "last": 11.450043,
              "first": 11.450043,
              "lastNotNull": 11.450043,
              "firstNotNull": 11.450043,
              "count": 51,
              "nonNullCount": 51,
              "allIsNull": false,
              "allIsZero": false,
              "range": 0,
              "diff": 0,
              "delta": 0,
              "step": 0,
              "diffperc": 0,
              "previousDeltaUp": true
            "scopedVars": {
              "__series": {
                "text": "Series",
                "value": {
              "__field": {
                "text": "Field",
                "value": {}
            "seriesIndex": 2
      "length": 51
  "annotations": [],
  "request": {
    "app": "dashboard",
    "requestId": "Q287",
    "timezone": "browser",
    "panelId": 2,
    "dashboardId": 5,
    "range": {
      "from": "2021-11-28T03:27:27.516Z",
      "to": "2021-11-28T09:27:27.516Z",
      "raw": {
        "from": "now-6h",
        "to": "now"
    "timeInfo": "",
    "interval": "1m",
    "intervalMs": 60000,
    "targets": [
        "format": "table",
        "group": [],
        "metricColumn": "none",
        "rawQuery": true,
        "rawSql": "SELECT REPLACE(REPLACE(REPLACE(c1.READING,\"aircraft.\",\"\"),\".lon\",\"\"),\".lat\",\"\") as Aircraft , c1.VALUE as lat, c2.VALUE as lon  \nFROM `current` c1\n  join `current` c2 on c1.device = c2.device \n    and c1.`READING` Like '%lat%'\n    and c2.`READING` Like '%lon%'    \n  WHERE c1.DEVICE = 'FR24_aircraft'\n  GROUP BY Aircraft",
        "refId": "A",
        "select": [
              "params": [
                "id"
              "type": "column"
        "table": "history",
        "timeColumn": "TIMESTAMP",
        "timeColumnType": "timestamp",
        "where": [
            "name": "$__timeFilter",
            "params": [],
            "type": "macro"
        "datasource": "FHEM"
    "maxDataPoints": 726,
    "scopedVars": {
      "__interval": {
        "text": "1m",
        "value": "1m"
      "__interval_ms": {
        "text": "60000",
        "value": 60000
    "startTime": 1638093026577,
    "rangeRaw": {
      "from": "now-6h",
      "to": "now"
    "endTime": 1638093026848
  "timeRange": {
    "raw": {
      "from": "now-6h",
      "to": "now"
  "timings": {
    "dataProcessingTime": 0
  "structureRev": 2
Does anyone have an idea what i am doing wrong?
