Grafana v10.0.2 (b2bbe10fbc)
via Docker -
I have data coming in from Prometheus that looks like this:my_metric {universe="1",address="1",state="ok"} 1 my_metric {universe="1",address="1",state="failed"} 0 my_metric {universe="1",address="1",state="failed_due_to_adjacent"} 0 my_metric {universe="1",address="2",state="ok"} 1 my_metric {universe="1",address="2",state="failed"} 0 my_metric {universe="1",address="2",state="failed_due_to_adjacent"} 0 my_metric {universe="2",address="46",state="ok"} 0 my_metric {universe="2",address="46",state="failed"} 0 my_metric {universe="2",address="46",state="failed_due_to_adjacent"} 1 my_metric {universe="2",address="47",state="ok"} 0 my_metric {universe="2",address="47",state="failed"} 1 my_metric {universe="2",address="47",state="failed_due_to_adjacent"} 0
This effectively represents an enum called
state
for an instance uniquely identified byuniverse
andaddress
. When I show this in some visualizations I set the legend to{{universe}}.{{address}}
to uniquely separate them.I am trying to end up with a visualization like state timeline where I can see a row for each
and then the current state. -
I went into table view and then filtered where the value is greater than 0, but I’m not sure where to go from there. I can’t figure out how to combine theuniverse
andaddress
into one field (I need string concatenation there I think, with a separator in between).
I think then I somehow need to map the different state values to numbers so that I can set value mappings for the names (or maybe there is a way to automatically use thestate
field as a value?). -
What happened?
N/A -
N/A -
N/A, I didn’t really get anywhere -
N/A -
N/A
Thanks!
Perry
