Hey, my options to run test look like this:
concurrentTests: {
scenarios: {
test_suite_flow2: {
executor: 'constant-vus',
gracefulStop: '30s',
exec: 'testSuiteFlow',
vus: 30,
duration: '5m',
thresholds: {
http_req_duration: [
threshold: 'avg<2000', // if http req duration is avg over 2000, test aborts
abortOnFail: false // abort test if thresholds breached use true
// delayAbortEval: '5s' // delay of abort so data can be gathered in metrics
http_req_failed: [
threshold: 'rate<0.50', // During the whole test execution, the error rate must be lower than 1%.
Right now you see vus:30, but if I put vus:40 or more i get instantly error:
ERRO[0002] Exception raised in test "API Calls". Failing the test and continuing.
TypeError: Cannot read property '0' of undefined source=console
How can I debug this ? is there some sort of limit for this executor to have specific amount of VU’s ?
