I’m trying to apply a constant variable to a query, but the replacement is not working properly, in a case like this:
FROM $myconstantvar_restOfTheName.report
Grafana doesn’t realize it has to replace it. It just works if I add some character to delimit a start and end, like " ", [[ ]], etc. The documentation says the way to do it would be:
FROM [[$myconstantvar]]_restOfTheName.report
It replaces the value in did, but it doesn’t eliminate those characters, resulting in:
FROM [[myValue]]_restOfTheName.report
When it was supposed to replace for:
FROM myValue_restOfTheName.report
Can someone help me, please?
