I have a actual Debian Bullseye server (without any desktop environment) with Grafana v8.3.3 and MariaDB on it. Additional I installed PGadmin Server to inspect the data of my remote PostgreSQL (V11) database. If I connect to this with PGadmin it’s connecting fast and also queries are done in a normal time.
But if I create a connection with Grafana by using the same credentials everything is extremely slow. The connection test takes over 1 minute. It’s reporting then a success, but off course I can’t create a query with this performance - it runs in a timeout.
I fond a interesting point at Grafana-Log in this context:
t=2022-01-07T12:03:19+0100 lvl=eror msg="query error" logger=tsdb.postgres err="dial tcp 192.168.97.21:5432: connect: connection timed out"
This IP is not a IP of my systems. Everything is on another private network. I can’t find any setting with this IP at the config-files.
Maybe this is the problem, but how can I fix it? Or is there a incompatibility with PGadmin on the same server?
Niels
