I can connect directly to a SQL server in a cluster, but when I try and connect to the listener of the cluster, the connection request times out. We are connecting on port 1633.
Cluster is hosted on Virtual machines in Azure.
When I connect from SSMS to the listener using the same user, I am able to connect.
Will do; trying to get the Grafana logs.
the user that I am using to access the listener can access the two nodes independently, can make queries on those nodes via grafana, and can login via the listener on SSMS. I’ll have a look if there is some other privacy issue in the environ, as that does sound like a feasible issue.
Thanks; that detail of it we have working; it’s the connection via the listener that is the issue. At the moment if the cluster fails to the secondary we need to change the connection in Grafana; it makes it tricky, and masks the monitoring of that particular incident too.
