Hi All,
Use case: I have data in a MySQL database that contains the time column as a 32 bit integer. I use the unix timestamp conversion query to convert that time into something Grafana can display, which leads to data being plotted in a band of usually 2 to 3 years, Eg. 2035 to 2038. I am interested only in the relative occurrence of events over time, and not on the actual date itself, hence I don’t care about times.
However I need to manually go over the panel data and see at what year the data points got plotted. Is there a way for Grafana to automatically detect the years in which the data got plotted and set the timespan accordingly?
