Grafana Version 8.2.5 -
Trying to configure the server to disable support for static key cipher suites -
I have tried setting
tls_min_version = tls13
tls_min_version = tls1.3
- What happened?
However scans still show up that insecure cipher suites: TLS 1.2 ciphers are being used.
I expected to be able to disable support for static key ciphers. -
No -
Configure Grafana | Grafana documentation
