Configure data source with read/write access account (server misbehaving)
Try to add a datasource using read/write access account to MS SQL Server. Got the following error for the latest Linux version (No problem though for windows’ version). Have no db admin access so can’t create a read only account. Therefore, can’t use the datasource under linux. Any setting to tweak so the security warning/error can be ignored?
May be a dns issue. Have you tried using an IP address instead of hostname?
Exactly! Using the IP works out. Thanks a lot for the help!
