"Config from query results" does not work with "Merge Series/Tables"
Hello Community,
I would like to Merge two Queries for Container Request and Container RSS into Table per a container (container’s column is omitted, security :slight_smile: ). And to use Gauge Gradient to help to visualize the result. I have 3 queries RSS, MAX (container request), QUERY (for providing max value to RSS column, QUERY is the same as MAX). However, if I merge the tables, the “Config from query results” does not show anything. It looks like it merges all table into a single one a there is no query for “Config from query results”.
Is there any option to workaround it? Or am I doing anything wrong?
Thanks a lot,
Petr
