8.3.x on Linux -
I retrieve a list of tags from influxdb to fill a query variable, and I want to add a hardcoded value to the results -
writing a query that retrieves the tags from influxdb and unioning it with the hard coded values -
What happened?
an error is displayed and the query variable results are empty -
Retrieve a list of tags with the hard-coded values appended -
I’m trying to copy them, but they dissappear as soon as the mouse hovers over them. See attached screen shot. -
No
Maybe what I’m trying is not the right approach to what I want, but is there a way to achieve this:
desired result:
- hardcode value
- value 1 from influxdb
- value 2 from influxdb
What I have now is the list above without the hard coded value at the top.
Perhaps I can create a Custom variable with the hard-coded value and append the result of the query to it?
Or is this a use case for a scripted dashboard maybe?
