Coloring an Entire Table Row
I’m a very new user to Grafana, and I’m really liking it so far.
I have a table that displays a username, user full name and account status. Is there a way to colorize the entire row, if the status is “Disabled”? I’m on Grafana 6.1.6.
Thanks,
Brad Turnbough
what datsource are you using?
MySQL. Pardon my ignorance here, but isn’t this logic performed after the data has been queried? Thanks!
I asked you because this isn’t possible out de box, but you can do something to get the same result.
SELECT
TIME,
USER
( CASE STATE
WHEN “disable” then 0
WHEN “enable” then 1
) AS STATE
FROM yourtable
And next you can use value to text feature to show correct values. And trigger to coloring the cell or row
