Collaborate line with the bar if using the series mode in the multibar graph panel
hello, i have a problem,
how to collaborate line with the bar if using the series mode in the multibar graph panel,and how to bring up two toltips when touched on the bar and the line,the following example is desired
@seftynindi Hey I have the same use case. Did you achieve this finally?
