We are using Grafana 6.3.2 -
We are using Cloudwatch to monitor AmazonMQ QueueSize using Broker and metric. -
Using a graph and pulling the data in a linear format -
What happened?
The values that are coming into Grafana do not match the values in Cloudwatch. We have created the queue that’s identical in Cloudwatch. The data is not the same. -
Example: Amazon Cloudwatch pulls a value of 19 and Grafana shows 96. -
Metric: AWS/AmazonMQ QueueSize: Average
Broker=BrokerName Queue=QueueName
The same queue is used in AmazonMQ (Cloudwatch).
No errors. The data is off and we’re not sure why. -
