For the typical “BigCustomer you can’t say no” we would like to change the behavior of a couple of plugins but without forking the whole original code.
What are the steps to do to make the clone a new plugin (a pointer to the appropriate documentation is fine).
Until now my attempts generated 404:
system.js:4 Uncaught (in promise) Error: Fetch error: 404 Not Found
at system.js:4
OK, since forking was the whole option, I forked. We will merge from master and deploy the whole grafana as a package for the distribution.
BTW, for those wondering, I did the following:
Cloned the table directory in another directory, gave it the same name as the new plugin-id.
Changed some class name (just to be sure to avoid conflicts)
Rebuilt frontend,
Restarted grafana.
(and now happy hacking to me).
