When you click on a line, there comes a little popup with the actual value in it – this is very nice – however, the color does not match the color in the key as it should. I think this is (almost certainly) a bug. As you can see in the example. Key is green, popup is yellow… popup should also be green.
Hi @smyth,
Tooltip has seen a lot of active development between 7.5 and 8.2.0-beta2. What version are you running? Does the issue persist if you upgrade?
