URL similar to Lowes that requires location “Block” or “Allow” pop up. I am new to K6 and need to click on those window popup button somehow. Did anyone get this working?
Hi @neeha, welcome to the forum!
What do you mean with “URL similar to Lowes”?
I’m afraid it is not possible to click on these “browser pop ups”, but it is possible to set a specific location when creating a new browserContext
or a new page
. See the geolocation
field inside options for newContext and newPage.
Let me know if that works for your use case.
Hi @Daniel.J . Sorry for the late reply. Geolocation did not work but I found a workaround using Chrome settings and blocking Notifications/Location settings.
Some other issue I found is when I disable location on chrome settings (version 117) even for Incognito K6 chrome browser doesnt pick those settings. Not sure from where does K6 pick the driver from. I found a workaround for this one too but just FYI . If this can be fixed it be great.
