Chart ok - but I can not see any single data when I go on chart
Dear all,
I have this workflow:
ESP8266 (with ESPEasy and sensor) => MQTT => Node-Red => InfluxDB => Grafana
When I go on the chart I can see the time but no single data (see screenshot).
I am not able to implement an alert becaus of “no data” => maybe the same problem!?
(Grafana v6.5.1)
Please help!
Thanks!
jomaria9
Why the DISTINCT() in your SELECT?
The only way I get a graph is with DISTINCT (). What would be the typical / best query method?
I am a beginner and I have tried everything. But at this point I don´t know what to do…
Thanks!
jomaria9
Using MIN(), MEAN() or MAX() would make much more sense. Use one of those functions.
Thanks for the hint!
Now I use telegraf and changed the data type to float.
The problem was that the data was sent as a string…
Thank you so much!
