Changing permissions/ACL using the API or dashboard JSON
Hi everyone,
I want to change the permissions for View/Edit/Admin on dashboard level. However, since I need to do that often, I want to automate that.
So my question is, if that is possible by either using the API or to configure it in the dashboard JSON? Or is there any other way to change the ACL except for the Grafana UI?
Also if you can tell me where the ACL is saved that might help as well, unfortunately I couldn’t find a lot on that.
Thanks a lot in advance for your help!
Hi @smdb
Have you explored the dashboard permissions API?
Mea culpa… don’t know how I missed that.
Thanks!
