Is there a way to change the color of a panels Description/Panel Links icon color? Looking for a way to make it contrast more and draw attention that it is there against the rest of the panel.
Thanks.
Thanks.
Hi @robkirkland
Well, this definitely sounds like a feature request and for that, the best place is to use our GitHub Discussions where you can open it using this link.
Define your use case (like you had defined here) and try to provide as much detail as possible to get more upvotes and attention from the community and the engineers.
Once you created the request, paste here the link so that we can also add more detail into it.
I hope this helps.
