I’ve got promtail set up to take syslog from syslog-ng, as I have dozens of centos 5 hosts that I can’t set up the promtail client on. These hosts send to the host, which are picked up and converted to the proper log format and then are sent to promtail on port 1514.
I’ve set this up in promtail:
- job_name: syslog
syslog:
listen_address: 0.0.0.0:1514
idle_timeout: 60s
label_structured_data: yes
labels:
job: "syslog"
agent: syslog
relabel_configs:
- source_labels: ['__syslog_message_hostname']
target_label: 'host'
I thought the source label section would save a hostname, but instead each host is populating as an IP address instead of a hostname. Is there a way to accomplish this?
