Change time control automatically for each day with a static database
    OS: Linux Debian 10.3 on Raspberry
    Grafana v.8.2.3
    Plugins: CSV v.0.6.1
    I’m trying to display into a dashboard each day of a static database, inside this database there is only data from month of May.
    I try to display each day of the month of May every 5 seconds.
    Every 5 seconds the data must change to move to the next day of that month.
    My database is a CSV file that is perfectly working, i’m able to display the data properly, but I want to see it move forward in the month of May 2021,
    I am aware that my request is particular and that is also why I have not found any solution, is there a grafana parameter for such a request?
    I specify that this database only has data for the month of May 2021.
Thanking you in advance for possible answers.
please expand on this. I am still having some trouble visualizing this. It also might help if you shared some of your raw, unformatted data, or marked up a screenshot showing what you want to achieve :+1:
