Change threshold labels size for gauges
Hello all
How I can change and control of threshold labels for gauge like the red marker of the below screenshot.
Thank you in advance,
Hi @moabd
You can control the labels by using Value Mapping (link to documentation).
use the Range function and name e.g from 0-4000 to a text e.g. “All good”
I hope this helps.
