Change name value based on value
In grafana8, I have a pie chart graph, it has labels showing the value name and the value.
e.g.
john Value: 5
peter Value: 3
Lincoln Value: 1
I would like to add an emoji to number 1 on the list (and it should work dynamically) - so whomever has the highest value will have a crown (:crown:) prepended (or appended) to his/her name…
Is it possible (maybe with transformation or field overrides) ?
Yes that should work I have done a similar thing to override a compass bearing value 0-360 to substitute the number ranges with North, South, East and West. Similarly some String Values I have replaced the BLOCK TEXT output from an appliance for some more friendly CamelCase.
Thanks @brew
How exactly did you achieve this?
Value Mappings in this instance
@brew Thanks… but I only need to change the display label for a single value name (the one with the highest value).
So in my example:
john Value: 5
peter Value: 3
Lincoln Value: 1
I want to display:
:crown: john Value: 5
peter Value: 3
Lincoln Value: 1
and if Lincoln all of a sudden has the highest value:
:crown: Lincoln Value: 7
john Value: 5
peter Value: 3
Ah sorry I think you are now into complex queiries which is beyond me.
You could add the :crown: after the name
Value Mappings
1 → :crown: 1
Thus you could get
John: 5
Peter: 3
Lincoln: :crown: 1
sure… but how do I determine which one is highest value? The “crown” should only be added to the user (or value) that has the highest value
Sorry I think this then needs to be a more complex query which is beyond me.
What is your data source. In sql one can do the following
I am using elasticsearch as src
could you please post a sample es doc? (obfuscating sensitive data but keeping “schema” intact)
Then with infinity, you can use jsonata and work out the details
