11.4.0 (b58701869e) -
I want to merge the frames with non-time data and that have common data with the next ones. Like:
frame1:- data1;
- idToMerge1.
frame2:
- data2;
- idToMerge1;
- idToMerge2.
frame3:
- data3;
- idToMerge2.
I understand that merge transformation requires all the frames to have the shared field. But maybe there is another way to achieve it?
By usingmerge
transformation. I also tried to use filter of merge transformation to apply the transformation to certain frames consequently. But it seems the filter allows to select only one frame to apply transformation to. -
What happened?
The frames are not merged into single one -
The single frame with merged data:| data1 | data2 | data3 | idToMerge1 | idToMerge2 | |-------|-------|-------|------------|------------| | ... | ... | ... | ... | ... | | | | | | | | | | | | |
No -
Transform data | Grafana documentation
