Case_insensitive_login settings
    9.5.3
    Remove and prevent duplicate userids
[users]
case_insensitive_login = true
    Try to prevent duplicate userid by enable this feature in config file
[users]
  • What happened?
    The above setting didn’t appear to work and in Grafana official documentation I can not find this setting. If I logged with with same userid with diff auth provider Grafana still created another users (with diff case)
    [users]
    This to work. I can’t upgrade to 10 yet.
