When I set the connector Direction to Field (instead of Fixed), the arrow direction does not update when the value becomes negative. The connector color changes correctly based on the value, but the arrow/icon direction does not.
In my case, the field contains positive and negative numeric values (for example +4.8 and -4.8). I expected the connector to reverse direction automatically when the value is negative, but it stays in the same direction.
Is this a known bug, or does the direction field expect specific values like -1, 0, and 1 instead of arbitrary positive/negative numbers?
But the direction did not changed. Color change working correct, but not the line and not the animation (if I turn on):
positiv or negativ values did not change the direction
@infofcc3 I already postet my settings for the connection. Or did you mean other ones?
As I show in the video: Is not working here on my side. Now I´m searching the issue
