Cant write or select Group and Host when i create alert
I have updated my monitoring system two days ago :
  • Zabbix v6.4.1
  • Grafana v9.4.7
Since update, i cant create new alerts just because i cant write or select Group and Host in the box.
I cant update existing alert, same issue i cant modify the text in box. This is visible, but i cant modify.
This worked well before the update in 9.4.7.
Any help please ?
For more informations, i can naviguate in Explore menu and select Group and Host. That works there.
I just find this :
Alert Rule - Zabbix Data Source - Unable to populate fields - Grafana / Zabbix - Grafana Labs Community Forums
Apparently, i have to downgrade.
