Can't Use local Variables
Hi there,
I’m trying to use a local variables in my Dashboard.
After i create the variable i can’t see it or use it in Query code in the objects.
Variable
Query without the variable
Query with the variable but with error (when i write the code it doesn’t show
found the solution
Int code i need to put like this
“$empresa” when one result or ($empresa) for multi result
