Cannot get string to display point on Time Series
Hello all,
I’m trying to get a data point on a Time series dashboard to show both a code number (specifically 2) which is working, along with a subset value which indicates a direction (south or north). These are two different _fields with two seperate_values in my database, and any attempt to join them succeeds on a table, but when attempting to have both code and direction show on a data point, it only shows the code, so I have no way to differentiate directions (see below:
I currently am using an outer join to get the tables to show the data in the table at the same time.
I’m using grafana v9.1.6 with influx2+ and flux.
data = from(bucket: "bucket")
  |> filter(fn: (r) => r["serial"] == "serial")
  |> filter(fn: (r) => r["_measurement"] == "software")
  |> filter(fn: (r) => r["detection"] != "report")
data
  |> filter(fn: (r) => r._field == "vehicle")
  |> yield(name: "direction")
data
  |> filter(fn: (r) => r._field == "code")
  |> yield(name: "code")
can you show a table view of your data?
Not sure that it is possible if direction is not shown on the same chart. If it is, then it could be done like this:
I went with a different method of renaming the string to an integer and then converting and value mapping. Thanks.
