Can we pull data from external sources into Grafana Cloud?
Hi all, I was wondering if it is possible to pull data from external sources into Grafana Cloud? For example, say I would like to use FRED as the data source, how do I do that?
API link - St. Louis Fed Web Services: FRED® API
Thanks, it worked! Just wondering if we can use 2 Y-axis in a panel (left and right Y-axis)?
this might be one route to be able to do it.
it is a grafana plugin
How to
or use Dynamic Text plugin with chartjs
how to
